Api session event editor netcluster set scenario
Revision as of 12:08, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Scenario
0 REQUIRED (NET_CLUSTER Integer ID) Net Cluster
1 REQUIRED (SCENARIO Integer ID) Scenario
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editornetcluster/set_scenario/?f=JSON&token=API_TOKEN
with content:
[ 58, 65 ]
