Api session event editor netcluster generate clusters
Revision as of 12:08, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Generate Clusters
0 REQUIRED (NetType or multiple values in array [a, b, c]) NetType[]
1 REQUIRED (Enumeration) ClusteringType ADD_TO_EXISTING_FOR_BUILDINGS, MAP_SECTORS, PER_ATTRIBUTE, PER_BUILDING, PER_LOAD or PER_LOAD_UNIQUE_OWNER
2 REQUIRED (MultiPolygon with crs: EPSG:3857) MultiPolygon
3 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Integer[]
4 REQUIRED (Floating point number) Double
5 REQUIRED (STAKEHOLDER Integer ID) Stakeholder
6 REQUIRED (String) String
7 REQUIRED (true, false) Boolean true or false
8 OPTIONAL (Floating point number) Double
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editornetcluster/generate_clusters/?crs=3857&f=JSON&token=API_TOKEN
with content:
[ [ "ELECTRICITY", "ELECTRICITY", "HEAT" ], "PER_BUILDING", {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799445.612884254 ], [ 658712.5310485815, 6799445.612884254 ], [ 658712.5310485815, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
}, [ 1, 2, 3 ], 82, 88, "Text", false, "" ]
