Api session event editor measurement import
Revision as of 12:08, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Import multiple Measurement
0 REQUIRED (GeometryCollection with crs: EPSG:3857) Measurement
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Measurement Names
2 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Overlay
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editormeasurement/import/?crs=3857&f=JSON&token=API_TOKEN
with content:
 "type" : "GeometryCollection",
 "geometries" : [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799390.389308265 ], [ 658639.2386590744, 6799390.389308265 ], [ 658639.2386590744, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799368.380864402 ], [ 658696.0314500041, 6799368.380864402 ], [ 658696.0314500041, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799350.567565128 ], [ 658733.878693399, 6799350.567565128 ], [ 658733.878693399, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
}, [ "Measurement Name 1", "Measurement Name 2", "Measurement Name 3" ], [ 1, 2, 3 ], "" ]
