Api session event editor measure set levee height
Revision as of 12:08, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set the inner height of Levee Spatial of a Measure.
0 REQUIRED (MEASURE Integer ID) Measure IDs
1 REQUIRED (Integer number) Levee Spatial ID
2 OPTIONAL (Floating point number) Height value
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editormeasure/set_levee_height/?f=JSON&token=API_TOKEN
with content:
[ 66, 38, "" ]
