Api session event editor measure set image
Revision as of 12:08, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set the image of a Measure.
0 REQUIRED (MEASURE Integer ID or multiple values in array [1, 2, 3]) Measure IDs
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Image names
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editormeasure/set_image/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ "Image name 1", "Image name 2", "Image name 3" ] ]
