Api session event editor measure set grid automatic polygons
Revision as of 12:08, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Let the polygons be calculated automatically based on the Overlay specified in the Grid spatial of a Measure.
0 REQUIRED (MEASURE Integer ID) Measure ID
1 REQUIRED (Integer number) Grid Spatial ID
2 REQUIRED (true, false) Automatic calculation true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editormeasure/set_grid_automatic_polygons/?f=JSON&token=API_TOKEN
with content:
[ 3, 18, false ]
