Api session event editor measure set grid
Revision as of 12:08, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Change the Grids applied by a specified Measure.
0 REQUIRED (MEASURE Integer ID) Measure ID
1 REQUIRED (Integer number) Grid Spatial ID
2 REQUIRED (OVERLAY Integer ID or multiple values in array [1, 2, 3]) Overlay IDs
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editormeasure/set_grid/?f=JSON&token=API_TOKEN
with content:
[ 6, 13, [ 1, 2, 3 ] ]
