Api session event editor measure add building
Revision as of 12:07, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add a new Building to specified Measure
0 REQUIRED (MEASURE Integer ID or multiple values in array [1, 2, 3]) Measure IDs
200 Integer[] (Integer array)
Example POST: https://engine.tygron.com/api/session/event/editormeasure/add_building/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ] ]
