Api session event editor map set height sector
Revision as of 12:07, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Update Heightmap Sector Data
0 REQUIRED (HEIGHT Integer ID) Height Sector ID
1 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Header: sector widthPoints, columns, rows, baseX, baseY
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Matrix Data Array
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editormap/set_height_sector/?f=JSON&token=API_TOKEN
with content:
[ 7, [ 1, 2, 3 ], [ 1.0, 2.0, 3.0 ] ]
