Api session event editor geolink add
Revision as of 12:05, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add new Geo Link
0 REQUIRED (GeoLinkType or multiple values in array [a, b, c]) Geo LinkType[]
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) String[]
200 Integer[] (Integer array)
Example POST: https://engine.tygron.com/api/session/event/editorgeolink/add/?f=JSON&token=API_TOKEN
with content:
[ [ "STREET_OBJECT", "WATER_BOTTOM", "STREET_OBJECT" ], [ "Text 1", "Text 2", "Text 3" ] ]
