Api session event editor eventbundle remove event
Revision as of 12:05, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove Event
0 REQUIRED (EVENT_BUNDLE Integer ID) Event Bundle
1 REQUIRED (true, false) Boolean true or false
2 REQUIRED (Integer number) Integer
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoreventbundle/remove_event/?f=JSON&token=API_TOKEN
with content:
[ 9, false, 14 ]
