Api session event editor cinematic set keypoint paused
Revision as of 12:05, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Keypoint Paused
0 REQUIRED (CINEMATIC_DATA Integer ID) Cinematic
1 REQUIRED (Integer number) Integer
2 REQUIRED (true, false) Boolean true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorcinematic/set_keypoint_paused/?f=JSON&token=API_TOKEN
with content:
[ 88, 41, false ]
