Api session event editor cinematic remove keypoint
Revision as of 12:05, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove Keypoint
0 REQUIRED (CINEMATIC_DATA Integer ID or multiple values in array [1, 2, 3]) Cinematic
1 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Integer[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorcinematic/remove_keypoint/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]
