Api session event editor building set slanting roof height
Revision as of 12:05, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Change Height of the Slanting Roof of a Building section
0 REQUIRED (BUILDING Integer ID) Building ID
1 REQUIRED (Integer number) Section ID
2 REQUIRED (Floating point number) Slanting roof height
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/set_slanting_roof_height/?f=JSON&token=API_TOKEN
with content:
[ 87, 4, 48 ]
