Api session event editor building set decals
Revision as of 12:05, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Decals
0 REQUIRED (BUILDING Integer ID) Building
1 REQUIRED (Enumeration) FaceType BASEMENT, EXTRA, GROUND, ROOF or TOP
2 OPTIONAL (Floating point number or multiple values in array [1.0, 2.0, 3.0]) float[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/set_decals/?f=JSON&token=API_TOKEN
with content:
[ 83, "EXTRA", "" ]
