Api session event editor building remove sections
Revision as of 12:04, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove Sections
0 REQUIRED (BUILDING Integer ID or multiple values in array [1, 2, 3]) Building
1 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Integer[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/remove_sections/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ 1, 2, 3 ] ]
