Api session event editor building set attribute
Revision as of 12:04, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Building attribute value
0 REQUIRED (BUILDING Integer ID or multiple values in array [1, 2, 3]) Building
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Attribute Values
200 Boolean (Content was updated)
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/set_attribute/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], "Attribute Name", [ 1.0, 2.0, 3.0 ], "" ]
