Api session event editor building remove polygons
Revision as of 12:04, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Delete polygons for Building Section
0 REQUIRED (BUILDING Integer ID or multiple values in array [1, 2, 3]) Building ID
1 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Section ID
2 REQUIRED (MultiPolygon with crs: EPSG:3857) MultiPolygon
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/remove_polygons/?crs=3857&f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ 1, 2, 3 ], {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799342.166029027 ], [ 658661.6111337672, 6799342.166029027 ], [ 658661.6111337672, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
