Api session event editor building add polygons
Revision as of 12:04, 1 April 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add polygons for Building Section. In case the Building is empty, optionally set ownership to largest Plot Owner of provided MultiPolygon
0 REQUIRED (BUILDING Integer ID or multiple values in array [1, 2, 3]) Building ID
1 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Section ID
2 REQUIRED (MultiPolygon with crs: EPSG:3857 or multiple values in array [a, b, c]) MultiPolygon
3 REQUIRED (true, false) Use largest Owner true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/add_polygons/?crs=3857&f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ 1, 2, 3 ], [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799387.058235251 ], [ 658644.9556181248, 6799387.058235251 ], [ 658644.9556181248, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799384.217647982 ], [ 658751.8448868692, 6799384.217647982 ], [ 658751.8448868692, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799343.392233733 ], [ 658784.8651977932, 6799343.392233733 ], [ 658784.8651977932, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
} ], false ]
