Api session event editor unitdataoverride remove
API Event to Remove existing Unit Data Override
0 REQUIRED (UNIT_DATA_OVERRIDE Integer ID or multiple values in array [1, 2, 3]) Unit Data Override
Example POST: https://engine.tygron.com/api/session/event/editorunitdataoverride/remove/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ] ]
