Api session event editor measure set requires confirmation
API Event to Set whether the Measure should be confirmed by other Stakeholder.
| 0 | REQUIRED | (MEASURE Integer ID) | Measure ID | |
| 1 | REQUIRED | (true, false) | Confirmation Required Boolean | true or false |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editormeasure/set_requires_confirmation/?f=JSON&token=API_TOKEN
with content:
[ 41, false ]
