Api session event editor measure set event
API Event to Change an existing event of a specific Action Type of a Measure.
| 0 | REQUIRED | (MEASURE Integer ID or multiple values in array [1, 2, 3]) | Measure ID | |
| 1 | REQUIRED | (Boolean or multiple values in array [true, false, true]) | Server Side (false = Client Side) | |
| 2 | REQUIRED | (ActionType or multiple values in array [a, b, c]) | Action Type | |
| 3 | REQUIRED | (CodedEvent or multiple values in array [a, b, c]) | CodedEvent contents |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editormeasure/set_event/?f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ true, false, true ], [ "CONSTRUCTION_PLAN", "CONSTRUCTION_PLAN_CANCEL", "CONSTRUCTION_PLAN" ], [ {
"id" : -1,
"parameters" : [ ]
"id" : -1,
"parameters" : [ ]
"id" : -1,
"parameters" : [ ]
