Api session event editor building multi select
API Event to Multi Select
0 REQUIRED (FUNCTION Integer ID) Function
1 REQUIRED (Integer number) Integer
2 REQUIRED (true, false) Boolean true or false
3 REQUIRED (BUILDING Integer ID or multiple values in array [1, 2, 3]) Building
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/multi_select/?f=JSON&token=API_TOKEN
with content:
[ 83, 15, true, [ 1, 2, 3 ] ]
