Api session event editor projectasset add texture
API Event to Upload new Texture as a Project assets, auto rescaled to small, medium, large.
0 REQUIRED (String or multiple values in array ["a", "b", "c"]) Directory to upload to
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Filename. This should a simple file name, including extension
2 REQUIRED (byte or multiple values in array [a, b, c]) File data
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorprojectasset/add_texture/?f=JSON&token=API_TOKEN
with content:
[ [ "Directory to upload to 1", "Directory to upload to 2", "Directory to upload to 3" ], [ "Filename. This should a simple file name, including extension 1", "Filename. This should a simple file name, including extension 2", "Filename. This should a simple file name, including extension 3" ], [ [ 1, 2 ], [ 3, 4 ], [ 5, 6 ] ] ]
