Api session event editor overlay set overlay source
API Event to Add or remove specified Source to or from a specified SOURCE Overlay. Unincluded Source which are already related to the Overlay will remain related. Unincluded Source which are not related to the Overlay will remain unrelated.
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to a SOURCES Overlay)
1 REQUIRED (SOURCE Integer ID or multiple values in array [1, 2, 3]) Array of Source IDs
2 REQUIRED (true, false) Should be added to the Overlay (false removes the Source from the Overlay) true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_source/?f=JSON&token=API_TOKEN
with content:
[ 76, [ 1, 2, 3 ], true ]
