Api session event editor building multi select
API Event to Multi Select
| 0 | REQUIRED | (FUNCTION Integer ID) | Function | |
| 1 | REQUIRED | (Integer number) | Integer | |
| 2 | REQUIRED | (true, false) | Boolean | true or false |
| 3 | REQUIRED | (BUILDING Integer ID or multiple values in array [1, 2, 3]) | Building |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/multi_select/?f=JSON&token=API_TOKEN
with content:
[ 74, 99, true, [ 1, 2, 3 ] ]
