Api session event editor building add polygons
API Event to Add polygons for Building Section. In case the Building is empty, optionally set ownership to largest Plot Owner of provided MultiPolygon
0 REQUIRED (BUILDING Integer ID or multiple values in array [1, 2, 3]) Building ID
1 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Section ID
2 REQUIRED (MultiPolygon with crs: EPSG:3857 or multiple values in array [a, b, c]) MultiPolygon
3 REQUIRED (true, false) Use largest Owner true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/add_polygons/?crs=3857&f=JSON&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ 1, 2, 3 ], [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799452.195497277 ], [ 658647.070243319, 6799452.195497277 ], [ 658647.070243319, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799311.311206726 ], [ 658765.598071312, 6799311.311206726 ], [ 658765.598071312, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799456.371147248 ], [ 658773.4994934085, 6799456.371147248 ], [ 658773.4994934085, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
} ], false ]
