Api session event editor cinematic set keypoint orientation
Revision as of 08:13, 31 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Keypoint Orientation
0 REQUIRED (CINEMATIC_DATA Integer ID) Cinematic
1 REQUIRED (Integer number) Integer
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Float[]
3 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Float[]
4 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Float[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorcinematic/set_keypoint_orientation/?f=HTML&token=API_TOKEN
with content:
[ 82, 76, [ 1.0, 2.0, 3.0 ], [ 1.0, 2.0, 3.0 ], [ 1.0, 2.0, 3.0 ] ]
