Api session event editor overlay remove legend entry
Revision as of 07:53, 31 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove the specified legend entries from a specified Overlay. The Overlay must have a custom legend before entries can be removed from it.
0 REQUIRED (OVERLAY Integer ID) Overlay ID
1 REQUIRED (true, false) Remove from custom difference legend (false removes the entry from the normal custom legend) true or false
2 REQUIRED (Integer number or multiple values in array [1, 2, 3]) Ids of entries which should be removed
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/remove_legend_entry/?f=HTML&token=API_TOKEN
with content:
[ 17, false, [ 1, 2, 3 ] ]
