Api session event editor zoning import
Revision as of 14:17, 30 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Import Zone Collection
0 REQUIRED (GeometryCollection with crs: EPSG:3857) Collection of Zone geometries
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Zone Names
2 REQUIRED (String or multiple values in array ["a", "b", "c"]) Attribute Names
3 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) Attribute Values
4 REQUIRED (STAKEHOLDER Integer ID or multiple values in array [1, 2, 3]) Permitter
5 REQUIRED (true, false) Import as category Zone true or false
6 OPTIONAL (Floating point number) Buffer for Points and Lines to make Polygons (optional)
7 OPTIONAL (SOURCE Integer ID) Source (optional)
200 Integer[] (Integer array)
Example POST: https://engine.tygron.com/api/session/event/editorzoning/import/?crs=3857&f=HTML&token=API_TOKEN
with content:
 "type" : "GeometryCollection",
 "geometries" : [ {
 "type" : "MultiPolygon",
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799331.3884285055 ], [ 658674.9322980089, 6799331.3884285055 ], [ 658674.9322980089, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799392.60461063 ], [ 658727.3236801242, 6799392.60461063 ], [ 658727.3236801242, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
 "coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799405.3815899845 ], [ 658768.4419336122, 6799405.3815899845 ], [ 658768.4419336122, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
}, [ "Zone Name 1", "Zone Name 2", "Zone Name 3" ], [ "Attribute Name 1", "Attribute Name 2" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ], [ 7.0, 8.0 ], [ 9.0, 10.0 ], [ 11.0, 12.0 ] ], [ 1, 2, 3 ], true, 0.5, "" ]
