Api session event editor overlay set overlay source
Revision as of 14:15, 30 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Add or remove specified Sources to or from a specified SOURCE Overlay. Unincluded Source which are already related to the Overlay will remain related. Unincluded sources which are not related to the Overlay will remain unrelated.
0 REQUIRED (OVERLAY Integer ID) Overlay ID (must relate to a SOURCES Overlay)
1 REQUIRED (SOURCE Integer ID or multiple values in array [1, 2, 3]) Array of Source IDs
2 REQUIRED (true, false) Should be added to the Overlay (false removes the Sources from the Overlay) true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editoroverlay/set_overlay_source/?f=HTML&token=API_TOKEN
with content:
[ 7, [ 1, 2, 3 ], true ]
