Api session event editor building generate rotation angles
Revision as of 14:11, 30 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Calculation a rotation angle for Buildings having the identifying attribute polygons, optionally only for specified Building.
0 REQUIRED (String) Identifying attribute
1 REQUIRED (String) Rotation attribute
2 OPTIONAL (BUILDING Integer ID or multiple values in array [1, 2, 3]) Specific BuildingIDs only (optional)
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/generate_rotation_angles/?f=HTML&token=API_TOKEN
with content:
[ "Identifying attribute", "Rotation attribute", "" ]
