Api session event editor measure set event
Revision as of 13:55, 30 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Change an existing event of a specific Action Type of a Measure.
0 REQUIRED (MEASURE Integer ID or multiple values in array [1, 2, 3]) Measure ID
1 REQUIRED (Boolean or multiple values in array [true, false, true]) Server Side (false = Client Side)
2 REQUIRED (ActionType or multiple values in array [a, b, c]) Action Type
3 REQUIRED (CodedEvent or multiple values in array [a, b, c]) CodedEvent contents
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editormeasure/set_event/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ true, false, true ], [ "CONSTRUCTION_PLAN_CANCEL", "CONSTRUCTION_PLAN", "CONSTRUCTION_PLAN" ], [ {
 "id" : -1,
 "parameters" : [ ]
 "id" : -1,
 "parameters" : [ ]
 "id" : -1,
 "parameters" : [ ]
