Api session event editor measure import levees
API Event to Import Measure Levee Collection
| 0 | REQUIRED | (GeometryCollection with crs: EPSG:3857) | Collection of Levee Geometries | |
| 1 | REQUIRED | (LEVEE Integer ID or multiple values in array [1, 2, 3]) | Levee IDs | |
| 2 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Override Angles | |
| 3 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0]) | Override Heights | |
| 4 | REQUIRED | (Boolean or multiple values in array [true, false, true]) | Override relative height | |
| 5 | OPTIONAL | (MEASURE Integer ID) | Set for existing Measure ID (optional) | |
| 6 | OPTIONAL | (Floating point number) | Buffer for Points and Lines to make Polygons (optional) | |
| 7 | OPTIONAL | (SOURCE Integer ID) | Source (optional) |
| 200 | Integer (Measure ID) |
Example POST: https://engine.tygron.com/api/session/event/editormeasure/import_levees/?crs=3857&f=HTML&token=API_TOKEN
with content:
"type" : "GeometryCollection",
"geometries" : [ {
"type" : "MultiPolygon",
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799367.295954103 ], [ 658790.6893498257, 6799367.295954103 ], [ 658790.6893498257, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799329.236483161 ], [ 658745.369456263, 6799329.236483161 ], [ 658745.369456263, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
"coordinates" : [ [ [ [ 658636.7618515313, 6799461.8964563515 ], [ 658636.7618515313, 6799387.664032432 ], [ 658773.8795412544, 6799387.664032432 ], [ 658773.8795412544, 6799461.8964563515 ], [ 658636.7618515313, 6799461.8964563515 ] ] ] ]
}, [ 1, 2, 3 ], [ 1.0, 2.0, 3.0 ], [ 1.0, 2.0, 3.0 ], [ true, false, true ], "", "", "" ]
