Api session event editor customgeometry add
API Event to Add a custom geometry to render.
| 0 | REQUIRED | (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) | 3D Data array | |
| 1 | REQUIRED | (TColor or multiple values in array [a, b, c]) | Color | |
| 2 | REQUIRED | (String or multiple values in array ["a", "b", "c"]) | Texture Names | |
| 3 | REQUIRED | (boolean or multiple values in array [a, b, c]) | Use absolute height from 3D Data array | |
| 4 | REQUIRED | (boolean or multiple values in array [a, b, c]) | Render both the front and back face |
Example POST: https://engine.tygron.com/api/session/event/editorcustomgeometry/add/?f=HTML&token=API_TOKEN
with content:
[ [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ], [ {
"argb" : -687228079
"argb" : -1999442132
"argb" : -1055434243
} ], [ "Texture Name 1", "Texture Name 2", "Texture Name 3" ], [ true, false, true ], [ true, false, true ] ]
