Api session event editor building add geometry
API Event to Add a custom building geometry
| 0 | REQUIRED | (BUILDING Integer ID or multiple values in array [1, 2, 3]) | Building ID | |
| 1 | REQUIRED | (CUSTOM_GEOMETRIE Integer ID or multiple values in array [1, 2, 3]) | Custom Geometry ID | |
| 2 | REQUIRED | (boolean or multiple values in array [a, b, c]) | Primary building for geometry | |
| 204 | No Content |
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/add_geometry/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ 1, 2, 3 ], [ true, false, true ], "" ]
