Api session event editor netnode remove
Revision as of 12:55, 30 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Remove existing Net Node
0 REQUIRED (NET_NODE Integer ID or multiple values in array [1, 2, 3]) Net Node ID
Example POST: https://engine.tygron.com/api/session/event/editornetnode/remove/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ] ]
