Api session event editor building set function value
Revision as of 12:40, 30 March 2026 by Frank@tygron.nl (talk | contribs)
API Event to Set Function Value
0 REQUIRED (BUILDING Integer ID) Buildings
1 REQUIRED (Enumeration) FunctionValue ALIGN_ELEVATION, BASEMENT_COLOR, BASEMENT_HEIGHT_M, BOWEN_RATIO, CRITICAL_INFRASTRUCTURE, DEFAULT_FLOORS, DISTANCE_ZONE_M, DISTURBANCE_DISTANCE_M, DRAINAGE, EXTRA_COLOR, FLOOR_HEIGHT_M, FOLIAGE_CROWN_FACTOR, GROUND_COLOR, GROUND_INFILTRATION_MD, HEAT_EFFECT, HEIGHT_OFFSET_M, JAM_FACTOR_BUSES, JAM_FACTOR_CARS, JAM_FACTOR_TRUCKS, JAM_FACTOR_VANS, LIVABILITY_EFFECT, MAX_FLOORS, MIN_FLOORS, MONUMENTAL, NUM_AIRPLANES, NUM_BICYCLES, NUM_BUSES, NUM_CARS, NUM_PEDESTRIANS, NUM_SHIPS, NUM_TRAINS, NUM_TRAMS, NUM_TRUCKS, NUM_VANS, PIPES_PERMITTED, ROOF_COLOR, ROOT_DEPTH_M, SAFETY_DISTANCE_M, SEWERED, SLANTING_ROOF_HEIGHT, SOLAR_PANELS, SOLID, TERRAIN_MIX, TOP_COLOR, TRAFFIC_LANES, TRAFFIC_NOISE_SIGMA, TRAFFIC_NOISE_TAU, TRAFFIC_SPEED, VEGETATION_FRACTION, WATER_MANNING, WATER_MICRORELIEF_M, WATER_STORAGE_M2, WATER_TRANSPIRATION_FACTOR or ZONING_PERMIT_REQUIRED
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) double[]
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorbuilding/set_function_value/?f=HTML&token=API_TOKEN
with content:
[ 1, "BASEMENT_COLOR", [ 1.0, 2.0, 3.0 ] ]
