Api session event editor zoning set permitter
Revision as of 10:28, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Permitter {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(ZONE Integer ID) |Zones | |- |1 |REQUIRED |(STAKEHOLDER Integer ID) |Stakeholders | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Boolean (Content was updated) |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorzoning/set_permitter/?f=HTML&token=API_TOKEN with...")
0 REQUIRED (ZONE Integer ID) Zones
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholders
200 Boolean (Content was updated)
with content:
[ 60, 52 ]
