Api session event editor zoning set parent
Revision as of 10:28, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Parent {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(ZONE Integer ID) |Zones | |- |1 |REQUIRED |(Integer number) |Integer | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorzoning/set_parent/?f=HTML&token=API_TOKEN with content: <pre>[ 94, 19 ] </pre> {{article...")
0 REQUIRED (ZONE Integer ID) Zones
1 REQUIRED (Integer number) Integer
204 No Content
with content:
[ 94, 19 ]
