Api session event editor zoning set attributes
Revision as of 10:27, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set multiple Zoning attribute values {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(ZONE Integer ID or multiple values in array [1, 2, 3]) |Zones | |- |1 |REQUIRED |(String or multiple values in array ["a", "b", "c"]) |Attribute Names | |- |2 |REQUIRED |(Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) |Attribute Values | |- |3 |OPTIONAL |(SOURCE Integer ID...")
0 REQUIRED (ZONE Integer ID or multiple values in array [1, 2, 3]) Zones
1 REQUIRED (String or multiple values in array ["a", "b", "c"]) Attribute Names
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0] or matrix [[1.0, 2.0], [3.0, 4.0], [5.0, 6.0]]) Attribute Values
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorzoning/set_attributes/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], [ "Attribute Name 1", "Attribute Name 2", "Attribute Name 3" ], [ [ 1.0, 2.0 ], [ 3.0, 4.0 ], [ 5.0, 6.0 ] ], "" ]
