Api session event editor zoning set attribute
Revision as of 10:27, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Zoning attribute value {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(ZONE Integer ID or multiple values in array [1, 2, 3]) |Zones | |- |1 |REQUIRED |(String) |Attribute Name | |- |2 |REQUIRED |(Floating point number or multiple values in array [1.0, 2.0, 3.0]) |Attribute Values | |- |3 |OPTIONAL |(SOURCE Integer ID) |Source (optional) | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |...")
0 REQUIRED (ZONE Integer ID or multiple values in array [1, 2, 3]) Zones
2 REQUIRED (Floating point number or multiple values in array [1.0, 2.0, 3.0]) Attribute Values
200 Boolean (Content was updated)
Example POST: https://engine.tygron.com/api/session/event/editorzoning/set_attribute/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], "Attribute Name", [ 1.0, 2.0, 3.0 ], "" ]
