Api session event editor zoning remove
Revision as of 10:27, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Remove existing Zoning {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(ZONE Integer ID or multiple values in array [1, 2, 3]) |Zones | |- |1 |REQUIRED |(true, false) |Remove Children |true or false |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Boolean (True when at least one item was removed) |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/s...")
0 REQUIRED (ZONE Integer ID or multiple values in array [1, 2, 3]) Zones
1 REQUIRED (true, false) Remove Children true or false
Example POST: https://engine.tygron.com/api/session/event/editorzoning/remove/?f=HTML&token=API_TOKEN
with content:
[ [ 1, 2, 3 ], false ]
