Api session event editor stakeholder transfer ownership
Revision as of 10:25, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Transfer Ownership {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(STAKEHOLDER Integer ID) |Stakeholders | |- |1 |REQUIRED |(STAKEHOLDER Integer ID) |Stakeholders | |- |2 |REQUIRED |(true, false) |Boolean |true or false |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/...")
0 REQUIRED (STAKEHOLDER Integer ID) Stakeholders
1 REQUIRED (STAKEHOLDER Integer ID) Stakeholders
2 REQUIRED (true, false) Boolean true or false
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorstakeholder/transfer_ownership/?f=HTML&token=API_TOKEN
with content:
[ 31, 20, false ]
