Api session event editor scenario set limit neighborhoods
Revision as of 10:22, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Limit Neighborhoods {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(SCENARIO Integer ID) |Scenarios | |- |1 |REQUIRED |(NEIGHBORHOOD Integer ID or multiple values in array [1, 2, 3]) |Neighborhoods | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorscenario...")
0 REQUIRED (SCENARIO Integer ID) Scenarios
1 REQUIRED (NEIGHBORHOOD Integer ID or multiple values in array [1, 2, 3]) Neighborhoods
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorscenario/set_limit_neighborhoods/?f=HTML&token=API_TOKEN
with content:
[ 24, [ 1, 2, 3 ] ]
