Api session event editor scenario set event
Revision as of 10:22, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Set Event {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(SCENARIO Integer ID) |Scenarios | |- |1 |REQUIRED |(CodedEvent) |CodedEvent | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorscenario/set_event/?f=HTML&token=API_TOKEN with content: <pre>[ 86, { "id" : -1,...")
0 REQUIRED (SCENARIO Integer ID) Scenarios
1 REQUIRED (CodedEvent) CodedEvent
204 No Content
with content:
[ 86, {
 "id" : -1,
 "parameters" : [ ]
