Api session event editor scenario add measure
Revision as of 10:22, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Add a Measure that is triggered on Scenario activation. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(SCENARIO Integer ID) |Scenario ID | |- |1 |REQUIRED |(MEASURE Integer ID) |Measure ID | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorscenario/add_mea...")
0 REQUIRED (SCENARIO Integer ID) Scenario ID
1 REQUIRED (MEASURE Integer ID) Measure ID
204 No Content
Example POST: https://engine.tygron.com/api/session/event/editorscenario/add_measure/?f=HTML&token=API_TOKEN
with content:
[ 90, 37 ]
