Api session event editor scenario set active
Revision as of 10:22, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Activate Scenario, when testrun is active the Scenerio can restart it. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(SCENARIO Integer ID) |Scenario ID | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |204 |No Content |- |300-600 |Codes Overview |} ===Example POST=== Example POST: https://engine.tygron.com/api/session/event/editorscenario/set_active/?f=HTML&token=API_TOKEN with content: <...")
0 REQUIRED (SCENARIO Integer ID) Scenario ID
204 No Content
with content:
[ 85 ]
