Api session event editor projectasset add
Revision as of 10:21, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Upload a new image as a Project asset. {|class=wikitable !Name !Importance !Type !Description !Values |- |0 |REQUIRED |(String) |Directory to upload to | |- |1 |REQUIRED |(String) |Filename. This should a simple file name, including extension | |- |2 |REQUIRED |(byte or multiple values in array [a, b, c]) |File data | |} ===Response Codes=== {|class=wikitable !Response Code: !Description |- |200 |Integer (Project Asset ID) |- |300-600 |Codes Overview |} ===E...")
0 REQUIRED (String) Directory to upload to
1 REQUIRED (String) Filename. This should a simple file name, including extension
2 REQUIRED (byte or multiple values in array [a, b, c]) File data
200 Integer (Project Asset ID)
Example POST: https://engine.tygron.com/api/session/event/editorprojectasset/add/?f=HTML&token=API_TOKEN
with content:
[ "Directory to upload to", "Filename. This should a simple file name, including extension", [ 1, 2, 3 ] ]
