Api session event editor overlay refresh grid
Revision as of 10:19, 30 March 2026 by Frank@tygron.nl (talk | contribs) (Created page with "API Event to Deprecated functionality, entire map is always updated when UPDATE is called. Note that when the "Auto calculation" is not active, an editor/update/ event is required to generate the new Overlay results. Or for long-running updates use: editor/set_scheduled_update/ to schedule an update. {|class=wikitable !Name !Importance !Type !Description !Values |} ===Response Codes=== {|class=wikitable !Response Code: !Description |} ===Example POST=== Example POST:...")
Example POST:
with content:
